Radio Shack pro 433
Jeremy173
Moncton NB Canada
Hey all, just in need of some advice. I am trying to program a radioshack pro 433 scanner for trunk mode. I can in put the frequencies however the scanner won't accept the frequencies for the trunk, it steps them up 12.5 mhz. So when I put in 858.6625 it will only accept 858.675. I can get them all input but then the scanner will not pick up the id's in my scan lists... any way to change the input so it won't step the frequencies up?
N8IAA
Fortunately, GA
Soryy to inform you, but the 433 does not support rebanded frequencies.
Larry
DickH
The step size is 12.5 KHZ, not m12.5 MHZ, but that has nothing to do with your problem.
Larry is not correct. 858.6625 and every freq. in the 854 to 861 range is available in your PRO-433. Rebanding does NOT affect those freqs. It only affects 851 to 854.
There must be some other problem. Make sure it is set to E2-800 per the trunking setup instructions on page 24.
OntFF221
Ontario, CANADA
I had an issue with the Pro-164; that was exactly the same...
The US (FCC) has different step-sizes then Canada (CRTC/IC) - your RS scanner is "correcting" the entered values to the closest "legal" step, according to the US spec's.
I couldn't find a work around for the 164; and traded it for a 106.
SkipSanders
Silent Key
It sounds like the scanner isn't liking a 'splinter' system. Normal 800 Systems use 868.6375, etc, while 'splinter' systems (normally near the borders) use the even 25 KHz slots, between them, like 868.625
Jeremy173
Moncton NB Canada
Not too sure what to say, thank you for all the help and advice. I even did a limit search with the pro 433 scanner and my pro 106 scanner. My scanner finds the right frequencies but the pro 433 doesn't. Mine will find the frequency 858.6625 but the pro 433 will find 858.675, I've made sure I am in E2-800 as per page 24 of the manual but it doesn't seem to help....
DickH
It definitely should allow you to enter those freqs. Here are the specifications from the PRO-433 Service Manual. Try re-setting the memory, page 38.
GENERAL
1. Band Coverage: 18 Bands
2. Frequency Range
Conventional Mode:
[Range] [Step] [Mode]
29.000 to 29.995 MHz 5 kHz FM (10 Meter Amateur Band)
30.000 to 49.995 MHz 5 kHz FM (VHF Low Band)
50.000 to 54.000 MHz 5 kHz FM (6 Meter Amateur Band)
108.000 to 136.9875 MHz 12.5 kHz AM (Aircraft Band)
137.000 to 143.995 MHz 5 kHz FM (Military Land Mobile)
144.000 to 147.995 MHz 5 kHz FM (2 Meter Amateur Band)
148.000 to 174.000 MHz 5 kHz FM (VHF High Band)
179.750 to 215.750 MHz 6 MHz WFM (VHF TV Band)
216.000 to 224.995 MHz 5 kHz FM (1.25 Meter Amateur Band)
225.000 to 399.9875 MHz 6.25kHz AM (UHF Aircraft Band)
400.000 to 419.99375 MHz 6.25 kHz FM (Federal Land Mobile)
420.000 to 449.99375 MHz 6.25 kHz FM (70 cm Amateur Band)
450.000 to 469.99375 MHz 6.25 kHz FM (UHF Standard Band)
470.000 to 512.000 MHz 12.5 kHz FM (UHF TV Band)
806.000 to 823.9875 MHz 12.5 kHz FM (Public Service Band)
849.0125 to 868.9875 MHz 12.5 kHz FM (Public Service Band)
894.0125 to 956.000 MHz 12.5 kHz FM (Public Service Band)
1240.000 to 1300.000 MHz 12.5 kHz FM (25 cm Amateur Band)
cfsimm2004
Harvest, AL
Pro-433
I am going to try to program my scanner and was wondering if anyone has a suggestions on a good software to use. I have only found a few for the Pro-433, I am really not doing so well with manualy programming it! The frequencies and talk groups and all are available for my area on the net (Huntsville, AL) Any help would be great, or if someone already has the file (Database) for this area and it works with the software I will be buying, that would be great! Thanks
