Radio shack pro 95
win95
Ventura
Need help programing southern california edison ( city of ventura & oxnard )
not sure how to do this, since these are trunked frequencies..
I know how to program regular frequencies ( non trunked )
Simply program all frequencies AS shown in the DB, making sure each channel is on proper mode( MOto E dacs etc ., As well as the bank. .
gmclam
Fair Oaks, CA
PRO-95 or PRO-97 programming
For the PRO-95, get yourself a programming cable and software. WIN95 is available for free at www.starrsoft.com and for the PRO-97 use WIN97 (30 day free trial) from the same site.
The manuals for these scanners are horrible, but there is good documentation here online. Go to the Wiki section, Radio Models, Radio Shack and select your scanner. There is info plus links to "easier to read manuals".
The software mimics the scanners. Once you understand the scanners, you'll understand the software. Some people like the software because it gives them a "total overview" of what is in the scanner. That's true.
Programming trunked frequencies into these scanners is as easy as it gets. Programming the newer digital scanners, especially "object oriented" is a lot tougher.
Step 1, pick a bank you are going to dedicate to the TRS you ar programming. After you get the hang of it and get things working, you can mix other stuff in to the bank. Don't program more than 1 TRS into a bank.
Step 2, program the CONTROL CHANNEL FREQUENCIES. There will be no more than 4 for a MOT system. If you are programming EDACS or LTR type systems (PRO-95 does not do LTR) you need to program in all the frequencies, and into proper channels. 01 would go into channel 01 of the bank you are programming, etc. For Motorola just use channels 00-03 of the bank and waste the other 96 slots.
Step 3, CLOSE the bank, unless you want to hear EVERYTHING on the system. If you want to everything, set the bank to OPEN.
Step 4, if you closed the bank in step 3, you'll need to program the TGs yo do want to hear.
The scanner only follows conversations in SCAN mode. If you listen in MAN mode you will hear data on the control channel as well as "parts" of conversations as they are 'randomly' assigned frequencies.
win95
Ventura
I can't find the frequencies on the db for southern california edison, city of ventura,or oxnard???
win95
Ventura
N4yek, I should have explained myself. I have looked on the radio reference Data base, but there is no frequency info for Ventura or Oxnard, California. (Southern California Edison )
n4yek
Newport, Tennessee
You need to be real specific about your question then because the link I gave you has plenty of frequencies for Ventura County. Oxnard is half way down the page and the Edison is a link at the bottom of that page.
win95
Ventura
n4yek
I KNOW WHERE TO FIND FREQUENCIES FOR VENTURA COUNTY, BUT MY PROBLEM WAS - I CAN'T FIND FREQUENCIES FOR SOUTHERN CALIFORNIA EDISON IN MY AREA. WHEN I CLICK ON THE LINK AT THE BOTTOM OF THE PAGE, I CAN'T FIND THE FREQUENCIES FOR MY LOCATION. (MY LOCATION IS VENTURA OR OXNARD CALIFORNIA )
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Site 999 list all of the control frequencies (32 of them). Enter all as Motorola in same bank also set to MOT. You should hear the noise on any when selected manually,.
List of Controls
Code:
Controls  01	 935.38750	  MOT	  0.0
Controls  02	 935.42500	  MOT	  0.0
Controls  03	 935.46250	  MOT	  0.0
Controls  04	 935.48750	  MOT	  0.0
Controls  05	 935.50000	  MOT	  0.0
Controls  06	 936.00000	  MOT	  0.0
Controls  07	 936.46250	  MOT	  0.0
Controls  08	 936.48750	  MOT	  0.0
Controls  09	 936.91250	  MOT	  0.0
Controls  10	 936.92500	  MOT	  0.0
Controls  11	 937.22500	  MOT	  0.0
Controls  12	 937.47500	  MOT	  0.0
Controls  13	 937.48750	  MOT	  0.0
Controls  14	 937.50000	  MOT	  0.0
Controls  15	 937.68750	  MOT	  0.0
Controls  16	 938.02500	  MOT	  0.0
Controls  17	 938.11250	  MOT	  0.0
Controls  18	 938.40000	  MOT	  0.0
Controls  19	 938.41250	  MOT	  0.0
Controls  20	 938.50000	  MOT	  0.0
Controls  21	 938.77500	  MOT	  0.0
Controls  22	 938.80000	  MOT	  0.0
Controls  23	 938.81250	  MOT	  0.0
Controls  24	 938.83750	  MOT	  0.0
Controls  25	 938.85000	  MOT	  0.0
Controls  26	 938.87500	  MOT	  0.0
Controls  27	 938.91250	  MOT	  0.0
Controls  28	 938.98750	  MOT	  0.0
Controls  29	 939.76250	  MOT	  0.0
Controls  30	 939.77500	  MOT	  0.0
Controls  31	 939.78750	  MOT	  0.0
Controls  32	 939.83750	  MOT	  0.0
You can hi light all>Copy then Paste into a Win95 bank.
