Hello All!
I have a Pro-97 and it seems to be working fine.
I am having a couple of problems.
1. The power connector is loose and will not charge the scanner unless it is held a certain way.
2. The display keeps getting light and dark and then fades in and out.
Is was just curious to see if the scanner is worth repairing or buying another one. Like I said the scanner receives great.
If so I live in North Carolina and would like to find someone that will fix it as cheap as possible.
David
David
