Pro-97
Hello......... I have a pro97 radio shack and I downloaded the win97 software also bought the cable from radio shack. I have been messing with it for two days and I can't figure out how the software works.
Hello and welcome to RadioReference.com!!! The PRO-97 is a great workhorse scanner, but might not work on some newly changed systems. So do let us know where you are and what system you are trying to monitor.
Is there any tutitoriols online anywhere? I have had the scanner for a few years and I wanted to reprogram it. So any help on the win97 program is greatly appreciated. Thanks.
WIN97 is the way to go. I've used it and versions for earlier scanners for about 5 years. In order to understand the software, you MUST understand the scanner. Read the manual on the scanner, then the software makes total sense. It is not something you will pick up "in a couple of hours".
You can read more about that scanner
here, and there are a lot of links to additional information. There is an easier to read online manual that helps some people.
The PRO-97 can work from the COM version cable or the USB version cable (20-047). RS is now only selling the USB version (~$35). Make sure to get it installed and working first, before worring about the software. Some people have trouble getting it to work because of needing the correct drivers and their operating system.
To see if it is working, and find out the COM port that has been assigned, go to device manager (through control panel) and look under "PORTS". You'll need to set that same COM port in WIN97. Also, I have never needed the adapter that came with the USB cable for ANY of my scanners. The USB version works with all the programmable scanners I have listed below.
Let's us know where you are having trouble. Good luck & Happy New Year!
