Can someone please advise me if the Radio Shack Pro-95 radio shack scanner is compatiable with the rebanding. If not, where can I send it to get the update for it?
Can I send it somewhere so they can update the version?
Do we have to send our scanners Pro-96, Pro-2096) in for update or is there a link online for an update does anyone know?
You can program it yourself with Win96.
http://www.radioreference.com/forums/showthread.php?t=100208
As you know, the UCAN Radio Engineers are aggressively changing sites all over the state now. They have begun with the smaller sites and working up, but I don't think you have much more than maybe a couple of months before it is all done and the dust starts to settle. As I recall, they originally intended to have this done by the end of 2008 and I would say they are doing their level best to hold to that schedule.Does anyone know when this is going to be completed?
Anyone wanna buy a pro-97 scanner.
You know, WalkieTalkie, using the information provided in the RR Wiki as a guideline telling you which scanners can be updated for use after rebanding, you might keep an eye on the secondary markets such as eBay, Amazon, even Craigs List, and don't forget the RR Classifieds Forums. You might luck out and find a perfectly good used scanner that will continue to give you scanning ability after the rebanding is finished until you could afford a new unit with all the bells and whistles.
The problem is that the band plan is different. The way I understand it the biggest obstacle is that the step size in the rebanded frequency list is 12.5 MHz compared to 25 MHz prior to rebanding. Without flashing the scanner, the scanner cannot make the correct step size moving from frequency to frequency so it cannot follow the conversations. That is why they published the "Custom Band Plan" for us to upload to our scanners...or at least for those of us running GRE scanners, so the scanner would understand the new step sizes. Some models of scanners just cannot be flashed so as to understand the difference; others can.I apologize I mistakenly stated that I have a pro-95 when I acctually have a pro-97. I know I know, it is not compatiable. Thank you for the links they were helpful. The only question I have is that the pro-97 did take the nelson peak control channel of 853.5500. So I am asking what difference will I see? Because it seems to be working.
I have the same problem with my beloved Uniden BC780XLTs. I can program the new CCs and the frequencies, but even in CC only mode, they cannot follow the conversations because of the step size.
The above frequency calculation, where channels 440-559 have moved, only affects voice frequencies. If that "rebanded" frequency 853.5500 MHz is used only as a control channel (and never voice), your PRO-97 will continue to work. As soon as a rebanded frequency (851.0250 - 854.0000 MHz, on 25 kHz steps) is used for voice, though, your PRO-97 won't be able to tune to the voice frequency.WalkieTalkie said:apologize I mistakenly stated that I have a pro-95 when I acctually have a pro-97. I know I know, it is not compatiable. Thank you for the links they were helpful. The only question I have is that the pro-97 did take the nelson peak control channel of 853.5500. So I am asking what difference will I see? Because it seems to be working.
Does anything need to be changed on a pro-164
I changed the Nelson Peak CC and it seams to be working, just don't know how to tell if I'm missing anything?
Not necessarily. Re-read the next post.So at the present time any scanner that I buy will not work unless I buy an expensive one costing more than $400. Am I correct?
As I said, there is a very good possibility that you could find an affordable, usable, used scanner that will fill your needs until you could afford a BIG NEW TOY. It is too bad that new ones cost so much, but you certainly are not the only one feeling the pinch.You know, WalkieTalkie, using the information provided in the RR Wiki as a guideline telling you which scanners can be updated for use after rebanding, you might keep an eye on the secondary markets such as eBay, Amazon, even Craigs List, and don't forget the RR Classifieds Forums. You might luck out and find a perfectly good used scanner that will continue to give you scanning ability after the rebanding is finished until you could afford a new unit with all the bells and whistles.
