Radio System Numbering
chief21
Western NC (Summer); Tampa Bay FL (Winter)
I'm familiar with the previous ID numbering for trunked radio systems (such as 1F20), but the newer ID's that I've been seeing have me stumped. What do these newer ID's (such as 00A.924B5) represent? And are they just for Motorola systems or others as well?
kd4efm
EL98 Florida
Harris uses the 00A (ID) and the 9xxxx is the WACN.
I have seen this with the Florida Power sites, but a different WACN.
then again, they all do some weird stuff with the data streams.
Bote
know-it-all
Ft. Lauderdale, FL, U.S.A.
As these trunked systems have expanded to cover entire states, and for the Feds and military whole regions of the country, they need larger address space to identify each site and system.
I can't check right now, but I'm pretty sure there's a wiki article on here discussing this.
APX8000
Sarcastic Member
AES-256 secured
Usually the pattern I see with Harris is they will use the 00A System ID but change the WACN on different systems UNLESS they build out systems set up for "Intra-WACN" roaming. Then you will see the same WACN and different site IDs per system. An example is City of Miami, Miami-Beach and Hialeah.
Project25_MASTR
TX-COMU
Texas
Another limitation of Vida perhaps?
