Radio to monitor 1 frequency
acosell
Hello everybody,
I am looking for a radio to monitor 1 frequency. I am looking for something relatively small and cheap.
Any suggestions?
It does not need to scan as it will be parked on this one frequency all the time.
CDS-INC
Banned
I would look into a 2 channel Radio, what frequency do you want to monitor?
You can also go the route of purchasing a scanner.
Also, if this is a fire department frequency, i would consider a Motorola Minitor Pager
zz0468
Banned
I use Motorola Maxtracs when I need a dedicated radio. They're cheap, and have excellent receivers. The drawback is the programming issue. But for one channel, you could probably find someone who would do it for you for little or no cost.
wmbio
Cumberland, Md
Regency used to make a radio called an RCD-1, single channel, crystal controlled, you had to but it for the band you wanted to listen to, low, high, or UHF band. It was the size of a Minitor and loud audio. Look around the net, you may snag one.
Wmbio
KC0QNB
Gothenburg, NE
Just a tip see if you can find Maxtracs. or other used (even crystal controlled units). Synthesized radios for a single channel rx only, are hard to find, and when you do find them they are quite pricey, $200-$600, they are some old 16 channel programmable scanners you can acquire fairly cheap. This is from a been there did that, point of view, I gave up.
af5rn
N. Tex / S. Fla
Can't really say what is best for your situation without knowing a LOT more information. What band? What type of system? How far away is it, and how strong does it come in? Are there co-channel users on the same frequency? Do you need PL? Mobile, portable, or base?
Don_Burke
Southeastern Virginia
I have a similar application.
It will take two radios on 453.850, one on a PL of 127.3 and one on a PL of 100.0.
I am already working on the two different antennas I will need.
This is in a fairly intermod heavy urban area, so I am thinking UHF business band radios.
iMONITOR
Silent Key
S.E. Michigan
Again, the Icom IC-R5 would be perfect!
Bill_White
Perry, N.Y. FNØ2xr
And ones budget…
“Small and cheap” are relative…
My Icom IC-R7100 is tiny compared to my Hallicrafters S-36.
A used IC-R7100 at $600.00 is cheap compared to a $13,500 IC-R9500.
acosell
Allow me to elaborate:
In the VHF high band I am looking to monitor a voice paging channel, all of the pages, not just certain tone-outs. no PL, and I am looking for a portable radio. Signal strength and distance are not an issue.
autovon
Ø
Motorola HT-600. Cheap and a lot of sellers on ebay will program them for you.
Thayne
There are tons of old UHF mobiles & portables out there, ask around any 2 way dealers in your area, they might give you one for mowing the lawn or something.
A few years back some guy gave me about 20 of various models of Unidens, Motos, and a few Kenwoods for replacing the hard drive in one of his computers.
(And he paid for the hard drive)
chrismol1
P25 TruCking!
A motorola Minitor 3 or 4 will work, minitor 5 if you can afford it. If you can find a minitor 2 with the crystal you want, jsut remove the tone reed filters
I'm getting a Minitor 4 programmed with NO TONES on my county fire control.
its perfect and its SMALL!! what i really wanted
elephant
Wmbio
I use to have one of these little gems back in the 80's. There was a retailer in Norfolk, Nebraska that would set it up for you. I had mine set up for 39.90, our local PD frequency. For such a little radio, that thing played for hours and hours on a 9v battery. And yes, the speaker put out quite a punch!
I gave mine away. Stupid thing now that I look back. I've done a google search but have turned up zilch. The business that I bought it from was bought out by "RXD" out of Kansas. Their web site shows that they are only selling crystals, now.
If anyone runs across one of those radios, please post a link. I'd love to have one, again.
JnglMassiv
Chicago / 016
How active is the paging freq expected to be? For a portable radio, you also have battery life to consider. Is this thing clipped to your belt all the time or will it primarily live on a desk? 'Small and cheap' are often exclusive of 'adequate audio and able to use drop charger', two features I'd consider essential.
If I were in your place, I'd look for a nice Motorola Saber 1 and a high capacity battery. If that's too big, I'd probably lean towards a scanner of some kind.
KC0QNB
Gothenburg, NE
Bernstrach or something like that?
