OldRabbit
- Joined
- Jul 15, 2020
- Messages
- 73
This thread is intended as a meeting point for those having issues with the new (From Radioddity) DB25-D DMR ultra compact mobile radio.
Unit appear to be a slightly updated Retevis RT-73 - apparently without the hardware receive/transmit interrupt issues reported on the RT73.
I have found the hardware to work perfectly after a week of use in my car. Only major hardware complaint is the need to press a 'Volume' button before turning the dial to adjust volume. Close to impossible to do safely while driving.
Also, small size and placement of dial on the left side of the unit make your hand cover the display while turning the dial - at least when using the right hand in a left side drivers vehicle.
Programming software has a serious bug, occasionally deleting/moving channels around - probably when you add a new zone. Do back-up the channels, zones, groups to a separate file (by hitting save after editing) - before you start working on another item - like switching from channels to zones.
Once learned, it worked fine, had never had any software crashes or connection issues to radio.
Range is excellent, can connect to repeaters not in line of sight and 20 km+ away - while parked in a city with lots of buildings between my vehicle and the repeater.
Audio is fine, especially on DMR and strong analog signals.
FM radio is useful, but inability to store channels is an annoyance.
Several people report crashes and lack of radio connection between software and radio, hope we can help each other resolve this.
