Radiofeed and Let's Encrypt
tcook
Running Radiofeed 8.1 and cannot get Let's Encrypt to work. Unsecure HTTP works, and I have set up port forwarding, but I sill get Challenge Failed. Any ideas would be greatly appreciated.
ProScan
Software Provider
Ontario, Calif.
Can you temporarily disable any antivirus software to see if that helps.
If it still doesn't work then verify your ISP is not blocking port 80 and the Port Forwarding is setup correctly by
1. Start the server using port 80 in the unsecure mode.
2. Use Open Port Check Tool -- Verify Port Forwarding on Your Router to see if the server can be seen or not.
tcook
Disabled Windows Firewall and confirmed Port 80 works in unsecure mode - still no luck. Is it possible to see the detailed Let's Encrypt response in order to see why the Challenge failed?
ProScan
Software Provider
Ontario, Calif.
Offhand, I don't believe the Challenge exemption shows any details on why it fails. You may want to try Wireshark or another sniffer to verify that.
