RadioFeed - multiple HTTPS instances on same machine?
WaveJam
Frederick, MD.
I have two RadioFeed 6.1 instances on the same machine. Running the web client on ports 5001 and 5002. Can I run HTTPS on both? Can they share the same cert file? I’m using a Globalsign cert.. I tried turning on HTTPS on just one instance, specified the cert, restarted and 5001 wasn’t responding at all (works fine with HTTP). btw, when I specified the cert, the cert was recognized as valid in the Certificate Details section.
belvdr
No longer interested in living
I don't about RadioFeed in particular, but you can use the same cert on two different sites, as long as the cert is valid for the site, regardless of whether they are on the same machine or even the same port.
webstar22
RenfrewCountyScanner.com
Ontario, Canada
You can use the same cert on any number of machines you want. But make sure port 443 is open and port forwarded if needed. Could be why the HTTPS isn't working. Also windows firewall as well.
