Let's back up a little here - Craig, using Scancrap ...er Scancat ... to load the scanner was your first error. The second was using Mr.Scanner data. We have our own databases here, and here's the entry for your county...
Jackson County, Missouri (MO) Scanner Frequencies and Radio Frequency Reference
Scancat Lite Plus (UGGHH) is a pure POS. Get yourself a copy of ARC433 (Scanner Master has it). It has the ability to download data from our database, once you get a premium subscription. To find out about that, float your mouse over
About in the upper right corner in the blue toolbar under the Scanner Master ad, and select
Premium Subscription.
To get started about understanding trunking, read the links in the Overview section of the wiki article on trunking. To get there, float your mouse over
Wiki in the blue toolbar under the Scanner Master article, go to the bottom of the pulldown and select
Trunking.
You have a couple of ways to go here. Go to the Missouri forum and ask for a file (be sure to state that you are using ARC433 when you get it and have a PRO-528) for your scanner. Get the premium sub as described earlier, or visit one of the Yahoo scanner mailing lists for your area, and ask, as listed here...
Missouri(US) - The RadioReference Wiki
I see the Mo folks are quite active. No doubt they can get you pointed in the right direction. More often than not, local help is the best help 73 Mike
