Radioshack PRO-94
chestnut1
Is there any way to press a couple of buttons to erase the memory of the scnaaer? Any help would be appreciated.
stevecubfan
thornton colorado
pro 94
1 turn off scanner 2. while holding down 2 and 9 turn on scanner clear flashes for about 5 seconds as the scanner clears its memory do not turn off scanner again until clear stops flashing.
Chicago IL
Need Trunking Help
I have no clue how to program trunked systems. I have read the manual and it seems all French to me. Someone who might be able to explain it in simple terms would be greatly appreciated.
benjaminarthurt
Liverpool NY
go back to the radio shack store and get a copy of the english manual.... that should be a start.
no but seriously, i dont own the 94, but I've sold a bunch and the county i work in has a trunking system so i program it alot, ive been selling the pro 97 alot more lately so im having a hard time remembering how to program the 94, ill pull one out of the display case when i get to work and see if i can help ya at all. Ill repost when i remember something
What kind of trunked system are you trying to monitor. Let me know and I can try to help.
-Clayton
clbarker
Lynchburg, VA
(I wrote this in another post, and im not sure where you are from, but I hope this helps...if it is an EDACS system, just leave out the pressing "E" part.)
The directions given by the radio shack manual is very unclear about how to program in trunked talkgroups. It took me over 2 years to figure it out. The basic steps are this:
1. Program in all the frequencies (do them in the order they are listed)
ex. xxx.xxxx (851.1551)
2. Press SCAN and then TRUNK.
3. There should be a scrolling text that pops up on the screen and says SCAN ID.
4. From here you can push PROG and then you will see something like
5. To program this, type in this:
ex. Chicago is on a Motorola Type II system. Say you wanted to program in the Chicago Auto Theft Unit (Detective Division) To do this, you will need to type in:
type in 29200. After that, press E until the small E in the upper right hand corner of the screen is blinking, or turns to an M.
I hope this helps, I'm not to familiar with how to program in Motorola Type II talkgroup ID's. While I have done this on vacation, Lynchburg is an EDACS system so I am a little more familiar with this system.
