Radtel RT-4D ARC4/AES128/AES256 DMR Encryption
Louie7
Forts
Ontario, Canada
So far... this is the worst 'cheap' radio that I've purchased. Really wanted to like it, but it absolutely does not work on DMR for me. Little broken snippets of audio and that's about it (doesn't even show any RSSI activity when a channel is active). Radtel messaged me to say it's likely something proprietary on what I'm trying to listen to (it isn't) and R&D is 'looking into it'. This was a month and a half ago and it's sat in the box ever since, so... just my experience but buyer beware.
Louie7
Thank you for this feedback. I don't have this radio, I relied on AliExpress reviews. if it's that bad, it's better to forget about it and stay on the MD380/390 PLUS which are more expensive but are better.
Forts
Ontario, Canada
Yeah I tried to return it but they wouldn't accept it as I couldn't provide a video of it "not working" haha. My go-to for an off-brand radio has been Anytone. Very happy with the AT-168UV and 878UV.
Louie7
Had you also bought it on AliExpress?
thatcrazydude
I recently got a pair of those and I'm not complaining as far as regular analog and DMR operations go. Considering it's a real cheap radio, that is.
There's only one "quirk" I'm not sure I can live with long-term: there doesn't seem to be a way to restrict remore stun/kill/wake commands, as in you can only disable RC it completely on the radio or you have it enabled, but then the radio will accept remote control from any other radio even if you're only using encrypted channels.
MTS2000des
5B2_BEE00 Czar
Bought a pair off Amazon for cheap AES radios. Really cannot complain. Adjusting the AGC down to 5 on digital produces clean audio. AES256 makes these great for cruise ship, amusement parks, etc where you don't want weirdo stalkers showing up. The CPS is fairly easy too. I really like these radios and this is from a guy that usually passes on CCRs but they work very well, are solidly built, and cheap enough. Sad that we can get AES encryption on DMR from Amazon but not on high tier MSI BMR radios unless you're a "special customer".
doriboni
Why do you say that?
on aliexpress we see RSSI activity :
AlanDeMan
Los Angeles, California
I just got my first DMR radio the Radtel RT-4D. I'm have a tough time getting DMR set up right. Any chance of a code plug with PAPA System (So. Calif) and maybe Brandmeister worldwide #91. This would help a lot. It would give me an example of real world DMR programming.
pb3400
You should really learn how to do it. Post specific questions and you can get an answer, but just copying someone else's work is a disservice to yourself.
