Radtel RT-950 Pro Radio Mode not working
chickenattack
Hi All,
I recently got a Radtel RT-950 Pro but the radio mode has only worked once or twice when I first got it. It is set to open when I press the lowest button on the side but it never seems to work. I googled this but not much comes up. Does anyone else have this issue? Thanks in advance.
EAFrizzle
Bond. Ward Bond
SE de DFW
Never had any problem with mine doing that. You could try assigning the radio function to another key to see if the problem is the button or the radio.
EAFrizzle
Bond. Ward Bond
SE de DFW
And welcome to the forums!
Does the radio do anything when you press the bottom side key? Sometimes mine seems a bit picky about how long I press those keys to differentiate between a long and short press. If the key seems OK, you could assign the radio to both long and short press on the key. That way, it'll come on with any keypress.
