ElroyJetson
I AM NOT YOUR TECH SUPPPORT.
For a long time now I've been suffering with a problem with my Rangr and S850 setup which
causes the talkgroups to be mixed up after programming into the control head. Some
are fine, but others aren't.
For example, I can program a given agency, call it the dog catchers, with 16 groups in
their list into the radio, and program another agency, call it the cat catchers, with 16 troups in their list, as well, and when I read the radio back, the dog catcher's list will have maybe half a dozen empty groups attached to the end of the list and the cat catcher's list will only have the first eleven entries in it. And some of the talkgroups will be assigned to the wrong names, too.
It's happened on clean installs on more than one computer and with more than one S-850 control head. I have FOUR control heads and the screw-up results are always the same.
Originally I had a LOT of system data in it and thought that maybe I just had too much data in there, so I started over and put in just ONE agency's lists. It still screwed up.
Any ideas?
I know, the S850/Rangr combo is getting kind of old, but it would serve my needs great
as the ultimate mobile scanner, and did for a long time until it started screwing up.
The only thing that changed between the time it was working properly and the time it
stopped working properly was that I went to add in a fourth site and new group data
for it, and once I put that in, it's never been right.
Any ideas?
