I was just wondering the data base says it's DMR Tier 3 with frequencies in the 217.xxxx mhz range but in my 536HP the database enters them as 800 MHz. Am I doing something wrong?
Ok thank you I will try to update on Monday when I get back to my laptop but yes it is from the sentinel and I am not to good at programming stuff direct into my scanner. Especially since I am an over the road truck driver so I don't do favorites anyway.Are you using Sentinel? Because earlier there were problems with getting this new system from the RR database, I programmed it manually. However, I just updated the Master Database and then put the REC system into a Favorites List. It's showing the system as MotoTRBO Trunk. I'm not seeing anything about 800 Mhz. The individual frequencies are the 217 mhz frequencies.
The way I post pictures from my Windows system is to do a ctrl-alt-print screen, paste into Microsoft Paint, crop the picture if needed to leave only what is relevant, save the result as a .png or .jpg, and upload the file. I've not run into any size limitations that way.After the update today now it is showing 462.xxx MHz now I tried to get a pic but it keeps saying it's to big of a file
