RadioReference.com Forums
I have been unable to happily install Liquidsoap on a Raspberry Pi-4 with Buster along with op25 and pulsaudio. Two instances of op25 are running as expected with audio output to speaker jack. The problem is when I installed liquidsoap using this command:
sudo apt-get install liquidsoap liquidsoap-plugin-all
it forces me to use:
(I do have a log of that loading process.)
I did notice that the liquidsoap folder in /usr/share/liquidsoap is empty.
When I run./op25.liq I do not get the results as described by boatbod ... OP25 - Experiments with op25 and liquidsoap
(and I also have the log of that outcome.)
I have spent 2 weeks researching issues with liquidsoap installed on Pi-4 and Buster but found limited information.
I have a number of Pi's running Darkice, TwoToneDetect and op25. But my knowledge and skills are limited with Raspbian.
On a side note I do have a Pi3 with Stretch, op25 and liquidsoap working fine.
I chose to post on RR because I see one of the feed providers is streaming a feed using Pi4, op25 and liquidsoap, but unable to contact do to privacy settings.
I will post the logs if ask.
