SDBud
I bought a Raspberry Pi 4 (8 gig) to run SDRs on, and other stuff.
I have 2 SDRs, a NoElec using an 820T chip, and a DVB with an 820T2.
Have OP25 set up and working, but when I try the command line to get the NAC, I get several errors,
starting with PLL not locked, and "value error, need more than 1 value to unpack".
The command like came from 2 different people, and is the same from both.
I have "./rx.py --args 'rtl' 'LNA47' -N 250000 -x 2 -f 855.6875 -o 17e3"
I have tried adding the -q 2" as one user showed, but he said that might not be necessary.
Also tried changing the 250000 to 100000 and several other values, with no difference.
Anyone have any ideas what else I can try??
