Update
Ran a test on the CORUNS 2300mAh that come stock with the HP-2. With a set that was fully charged (or as near as I can tell, due to currently using a "dumb" wall wart Energizer charger). Over the course of two days, I was able to get 8 hours and 42 minutes of listening time out of them before my low-battery indicator activated on the scanner.
I have started to log what times I will get out of the Energizer 2300mAh I currently have on hand to rotate with as well, to compare with the CORUNs.
Problem with this whole scenario is, I do not have my Maha C9000 yet, so it is unknown what my true starting mAh capacity is and therefore if I am getting true and accurate run times out of the batteries. The Energizer charger is obviously not capable of discharging, conditioning or properly recharging the batteries, like the Maha would.
So my run times are to be taken with a grain a salt. Also, we all know that everyone's listening environment may be different as is transmissions received, etc...causing more battery load then others may experience. I rate my area as not an "extremely" busy area, it is mostly suburban/rural. Obviously big city/metro listeners may experience less run times.
With all of that said and while currently conversing with folks on the CP forum, I have tentatively determined LSD (low self discharge) Eneloop type capabilities may not be the way to go in our application, if run times are what is important to you. In which that case, a HSD (high self discharge) with high capacity (mAh) capabilities may be optimal for us. Again, if run times versus having to constantly recharge is what is important to you. I prefer long run times in between recharges.
Currently now looking at the Powerex 2700mAh batteries as recommended by some CP folks. If I get other recommendations I will post here.
I have not given up on Eneloop all together though. I plan on purchasing a set a Pros regardless, along maybe with some Maha Powerex 2700s. At the end of the day, the quality of Eneloops can not be denied.
I will also add, for those that are unaware, that my quest for battery knowledge has revealed that the Duracell 2400mAh Ion Core AA batteries available at most local stores such as Wal-Mart, Target, etc.. are actually rebranded Enelooop Pros, for a fraction of the price. The guys at CP have tested and vetted this and have aptly nicknamed them "Duraloops." I will also be getting a set of these from my local Wal-Mart to try out as well. Can't beat that price for the performance.
As others have mentioned, another high capacity LSD option are the Amazon Basics Pro, another tested/vetted rebranded Eneloop.
But for now, higher mAh instead of LSD is where my priority is leaning.
I would appreciate, any feedback of the Maha Powerex batteries in our application from anybody here. Good or bad.
Thanks!
