RCMP Province-Wide p25 System
VA3JWO
Madoc, Ontario
heyy
i was searching the Middlesex County, scanner frequencies, and i found a new trunking system called
RCMP Province Wide P25 System
Does anybody know about this???
gary123
It is/was a portable trunked system for temporary operations in an area. It is used very infrequently.
mikewazowski
Staff member
Central Ontario
No, it's not the temporary system.
This is the new Provincewide UHF P25 trunking system the RCMP are rolling out.
I believe there's 9 sites active at this point.
mikewazowski
Staff member
Central Ontario
Since the site is just being built, it's too early to say but so far there's been a mix of unencrypted and encrypted voice with 90% of it being encrypted.
Once the system is live, that number will probably change to 100%.
Forts
Ontario, Canada
As Mike mentioned, pretty much all the traffic so far has been encrypted. From listening to the London sites I've heard a little bit of chatter (mainly test 1-2-3's) in clear P25, but the majority has been encrypted.
hawkeye32
Windsor
I wonder if windsor will be part of this? I know their is a RCMP place here, but i haven't come across any new freq's. Anybody know if Windsor is going to be part of this?
hawkeye32
Windsor
Is Windsor part of Ontario? Last time I checked it was.
uhm..ok yes i know that, but with windsor not being as big as GTA, was just curious if the same thing would be happening here, beings they are small here, as compared to GTA.
Forts
Ontario, Canada
RCMP Province Wide P25 System :)
I'm sure it will roll out in the most needed areas first before it trickles down to smaller areas. A border city like Windsor will be using the system for sure I would think.
VA3JWO
Madoc, Ontario
so....
anything else known with the RCMP since the last time this thread was active???
I live just south of Madoc, Ontario, and on the top of a big hill, i can just barely hear a faint control channel. I know what control channels sound like, and it sounds like its p25
i don't remember the frequencies, but when i do, i'l post them.
