RCT RDL-sr002 antenna switch.
P25Radio
Oceanside Ca.
I have acquired a 125 watt vhf Quantar repeater and said device was attached to it, Is this something for the repeater to TX and RX on 1 antenna not being used in a repeater mode as in like a remote base set up? What is it used for and how would it be set up, please explain.
kb4mdz
Cary, NC
Does it look similar to this relay?
If so, then yes, that's used when the station is used as a base instead of as a repeater. Antenna connector goes to the Common port, and a short jumper from the Normally Closed (NC) port to the Receiver jack, and a jumper from the Normally Open (NO) port to the Transmit port. Switching is accomplished from a line off the Quantar that goes to +V during transmit. Sorry, I've forgotten all my Quantar interfacing; it will be in your service manual. RelCom SR-012 Relay.jpg
