Rdio-scanner forums? I have some issues
bigRoN18
Roseville, CA
I am relatively new to Rdio-Scanner... since SDRTrunk added support. I have not found any other forum site yet for support of the software other than the RadioReference forums.
I am having issues with radio unit IDs. I would like to have Rdio-Scanner name the units when they are known. I have created what is essentially an alias for all of the unit IDs that belong to dispatch consoles. When in "Live" mode and the dispatcher is speaking, instead of displaying the alias of "Dispatch", it just shows the ID number... as if the unit alias did not exist. Another frustration is that it is ONLY in the "Live" display where the unit id is displayed; it will not display the unit ID if it is an older message.
webstar22
RenfrewCountyScanner.com
Ontario, Canada
In the image below, that is a recording(played it back for this image) and it shows the UID on my system.
And if you want numbers to names you need to populate them in Rdio yourself, it will not grab them from the other software.
OR you can use the import function to do them all from list.
