Rdio Scanner
NewbGuy
Kentucky
Hoping someone can give me some advice.
Running SDRTrunk to broadcastify, no issues.
I’m wanting to set up Rdio Scanner. How to do I need to go about setting up a SSL? I’ve read about Tailscale and Cloudflare?
Ideally, I want to be able to share my link and allow public to access it but also want it secured. Would be nice if I could also use it to remotely access my displayless computer that my SDRs run on from my laptop.
C_615
My advice is to take it one step at a time. It isn’t easy. IMHO, Tailscale is the most secure way. However, I do not publicly share mine.
As you go along, DOCUMENT EVERYTHING! Failing to do so is my biggest regret and causes me problems when pieces of the puzzle go down.
I would also suggest joining the Rdio Scanner discord group.
NewbGuy
Kentucky
I appreciate it.
This a learning experience for me.
I tackled some this evening, so far I have it connected and set up and can connect from the app using WiFi but if I turn it off I can’t so I need to do some work there.
Also trying to figure out if I need to set SDRTrunk to record even though I’m streaming directly to Rdio Scanner, quite system so I don’t have a large call volume to test my call search on the app.
C_615
I appreciate it.
You just need to stream to Rdio-Scanner.
I use Tailscale’s Funnel feature to access Rdio Scanner from outside of my network.
NewbGuy
Kentucky
I’ll look into that. I’m very new to command lines so I think maybe that where I’m struggling getting it set up. Ideally I’d like it to be secure as possible and from Rdio Scanner documentation, I need a config file but I’m having a hard time getting/finding that. Seems like I need to run command lines.
