Re-Banding
K1TA
Stamford, CT
Greenwich Rebanded
The spacing is not related to narrowband/wideband but the space between the designated Motorola channels.
Base is the frequency of the lowest Motorola channel (Ch1 - 851.0125) and spacing is the separation to the next channel (25khz).
So channel 1 is 851.0125, channel 2 is 851.0375, etc.
The interleaved channels start at 851.0250 and are also 25khz apart.
Ch 440 is 851.0250, ch 441 is 851.0500, etc.
If you create a custom plan and use 12.5khz, the scanner will not trunktrack correctly. Also, if you do not add the second part of the plan with the 851.0250 base, you will not trunktrack correctly IF the system has any of the interleaved frequencies.
chris
So this is correct for Greenwich Chris?
Band Plan 2
Lower 851.0125
Upper 868.9875
Step 25mhz
Offset 0
tpp517
Dennis, MA
I am using a 796D, I work in Greenwich,I have tried the band plans and none will work for me. I can track the system using the type 2 P25 setting but seem to miss a few transmisions. Spoke to Uniden tech support today and the tech had no idea why the band plan would not work.
cg
Connecticut
the way Dave had it should be correct. That is also what Uniden's WIKI reports as the correct custom plan for rebanded systems.
EDIT: looking at the frequencies, I am fairly certain you need to have BOTH plans in the custom plan. One covers the interleaved channels and the other covers the regular channels.
For the 796, try the plain 800. I believe it is not a P25 system. If it is, the rebanding should not have affected it.
(I have been away for 5 months so I haven't been following the very latest)
chris
izzyj4
Ova here
The last I knew and this may have changed but I didn't think the 796 / 780 series were going to be upgradable with the new bandplans since they had already switched over to the newer generation of scanners. There was no software to come out to flash the older trunkers.
garys
Central Texas
Band Plan update for the 796D is located here,
BC796DFirmwareUpdate < UnidenMan4 < TWiki
pro106import
Milford, Ct. perched high above Long Island Sound
Thanks Garys. I'll have to try it.
According to RR, the Greenwich site is Project 25. But right now it is analog rebanded. 853.700 is the Control Channel. I used the default tables and it tracks fine on the Pro-106, but again, it is analog, not p25 Auto.
Check that--- it is a mixed system. Just heard a P25 transmission. What happened to the talkgroup list that was on RR?
Lo Chan Hi Chan Offset Base Freq Step
440 559 440 851.025000 25.000
0 719 0 851.012500 25.000
720 759 720 866.000000 25.000
815 831 815 867.000000 25.000
958 958 958 868.975000 25.000
961 1022 961 867.425000 25.000
Dave520
Connecticut
The Greenwich system is a Type II system (rebanded) with both analog and digital communications. I sent an email to the database admin and they are going to put all the talkgroups back up. They thought that the system was changed over to full P25. If you check the database again you will see the correct system again listed as "Greenwich Type II"
N1SQB
Somewhere On Earth
While on the subject of the 796D, will it be able to track the CSP if and when they switch to 700 MHZ?
Manny
cg
Connecticut
No, the 796 only covers down to 806.0000 (input to 851.0000)
chris
K1TA
Stamford, CT
Greenwich Trunk
Has anyone been able to program a Uniden/Bearcat BCD396XT for Greenwich since rebanding???
I am having a HELL of a time
connscan
Hartford sets date to reband
The rebanding will take place on the weekend of January 24, 2010.
scollier
You got a long wait for CSP to go 700. They haven't even switched down to 850s yet. Why would they want to go 700. No depts that use 700 that I know of.
chris
Cskib32087
I would not say you have too much wait. A 6 channel 700 trunking system is going up at 4 or 5 of the fairfield county CSP sites including shelton in the next 3 months. I found the freqs on the FCC site and have been pluging people for months and thats what I got so far. an 800 system and 700 system can mix
xplorer417
AGAWAM MASSACHUSETTS
hi all just wondering what hartford system chs these are replacing 854.0125 856.03750 855.01250 854.5625 can't figure out whichs they are replacing please advise on it thanks
cg
Connecticut
For Hartford, the 860.xxxx channels will likely go away. You will need to wait until the event occurs because you have to program them in in the correct order once that is determined.
chris
PJH
CSP is going APCO25 Phase 1 as funds permit. Don't count on 700 on CSP anytime soon as 99% of the radios in the field do not support 700 (or APCO25Ph1) at this time.
This doesn't mean that the state isn't going to license some freq's. Cross check the 700 freq's with the 700 interop channels as well.
Dave520
Connecticut
Where did you find the freqs for Fairfield County? I could not find them. What is the call sign?
Since I am in lower Fairfield County, I will want them in my scanner.
Dave
wesct
Connecticut
Hartford Hospital Security 860.8125 MHz DPL025
Also, new trunk channel: 853.4625 from 868.4625
CCSU Police, New Britain: 856.8125 MHz DPL071
857.4125 MHz PL 114.8 RAFS 1
854.9125 MHz PL 114.8 RAFS 2
City of Hartford: WPSJ542 4 new channels
854.0125, 856.0375, 855.0125, 854.5625
West Hartford Has Re-Banded as of 6/25/2009
WPMN274
851.0750
851.3250
851.8000
852.5500
853.2875
853.8125
Windham County
Willimantic PD 854.2625 Mhz PL 162.2
New Haven County
Meriden PD 855.5125 MHz PL123.0
Meriden is also licensed for the I-Call re-banded frequencies
New Haven Fire :
854.4875 MHz DPL311
859.5625 MHz DPL311
Waterbury has new frequencies
WPLU572
ULS License - PubSafty/SpecEmer/PubSaftyNtlPlan,806-817/851-862MHz,Trunked License - WPLU572 - WATERBURY, CITY OF - Frequencies Summary
Note: This is a LTR Multinet system
New London County:
Groton Town PD
Ch 1 853.400 DCS 155
Ch 2 851.575 DCS 155
Sprague: 855.2625 MHz WQFI 471
Statewide:
Department of Corrections
854.1125 MHz; 857.6625 MHz; 859.5375 Mhz; and 859.6625 MHz- status pending
Fairfield County:
Shelton PD:
852.2500 - PL 110.9
853.4375 - PL 110.9
Just a refresh....
