suttles1972
Re: Eliminating Buzzing
Hi all. Need some help on trying to rectify a problem I'm having with my BC296D. Here's what I have. I'm using a Scantenna Dipole antenna with 125 feet of RG6 shielded coax. The coax has a ground at the base of the antenna and another ground at the end of the 100' coax wire. The remaining 25' goes indoors, where the wire goes through a noise and interference canceller and off to the bnc connector of the radio. By doing this, I've eliminated all pager intermod and increased my listening distance. However, during the early morning hours, I pick up what sounds like an idling motor of a 2 cycle engine. I manage to get rid of it, by locking out the frequency. But usually, this noise will find it's way to another channel, causing me to lock out a lot of important communication. Now here are the facts. The frequencies the noise becomes attracted to are all VHF frequencies, with it's favorite on 155.160. The noise doesn't affect communications, but will prevent the scanner from scanning after the voice transmissions are complete. So my question is, What can I do to eliminate this noise?
Thanks in adavnce.
Thanks in adavnce.
