Re-instating expired license
LoveRadios
SiliconValley
I let my advance license expired about 5 yrs ago. Now I want to take the Tech test to get back on the air.
Is the test taken via paper or computer at VE?
thanks
Blackswan73
Central Indiana
The test I took was paper, and you don't have to stop at tech. If you pass tech you can immediately take the general, and if you pass it you can go for your extra. All tests can be taken in the same session for the same cost. So go for it. You might be surprised at how much you remember.
ko6jw_2
Santa Ynez, CA
Paper as far as I know with the ARRL VEC. I'm a VE and I haven't heard anything to the contrary. If you passed Advanced you should be able to get Extra. The Extra test is now very similar to the old Advanced tests. You might be able to get your old call back.
k6cpo
San Diego, CA
thanks
If you can prove you once held an Advanced License (a copy of your old license or record in the FCC database) you can be granted a General license just by taking the Technician exam. The FCC now allows for the grandfathering of previously held licenses if satisfactory proof is provided. You will not be granted an Advanced license and you won't get your old call sign back. However, you can apply for your old call sign as a vanity if it is available.
LoveRadios
SiliconValley
Thanks K6CPO. Stupid me I mistakenly throw the old license away when I cleaned my file cabinet a year ago. I do find my call sign in the FCC database. Am I correct that I need to request a copy of the license from to FCC for the VE as proof?
Thanks.
n5acf
Dayton, Tx
Thanks.
You may be able to print one from the FCC website. Check the tabs if your name is still attached to that call sign even if expired. If you are able please post that you can so others like you will know. hope this helps.
k6cpo
San Diego, CA
Thanks.
A print-out of the record in the FCC database would be sufficient. It will also show an FRN, which you will need to put on your application when you take the Technician exam.
Once the license expires and goes beyond the two-year cancellation date, all downloadable authorizations (license copies) are purged from the record. However, as I said above, a copy of the license record as it appears in the FCC database is sufficient proof to show the license was once held.
