Anyone know how/if its possible to re-arrange your talkgroups in the Group ID settings screen? I have added 200+ TGIDs and have to do a lot of hunting and pecking when creating new zones/knob positions because I can't re-arrange the groups.
Not that I've found... got really hard after manually entering/adding hundreds of talkgroups to the profile to find anything - even if you entered them in order one after the other (which I didn't usually). It would be nice to have either an additional field/column to allow for naming (i.e. adding the system name) to talkgroups and/or the ability to sort and/or filter on them.
I also found it frustrating that if you add a talkgroup to a zone/knob and then removed it, the PPS pushes it to the end of the list of available talkgroups. Just things you have to learn to deal with... but the more groups you have defined, the harder this becomes to work with.
I finally gave up manually entering things and wrote a script to import the data from the RRDB when I want to create new profiles (easier than fighting with one big one).
Also, I've learned that if/when you have a larger number of talkgroups in a profile (even if you aren't using all of them), the radio will begin to "bog down" on busy systems to the point that you lose control of the radio. Now days, I use my script to import only what I want/need vs. loading things up for the "possibility" that I'll need/use them later.
