im not sure if im in the right spot does any one know what the netset 200 channel pro2032 digital scanner is it a good scanner to get a friend has a chance to get one but dont know if its a good scanner thanks
I hope it is not for a lot of money. It is probably around 20 or so years old. There are two models, european and US. The Eu has 66-88MHz for the low end, the US has 25-54MHz. All the rest is the same. If you have analog comms to monitor in the province, it should work. It won't do P-25 digital, however. HTH, Larry
thank you very much can you belive he is asking 250.00 for it and he said it will work for all the police but he doesnt want to tell me how old it is that is why i came here cause i know i will get the truth thanks again
I just looked it up on line the manufacture date is 10/29/1993. Rough guess I would pay between 50 and 75 dollars tops. WIll not do trunking and is only analog
