SDS100/SDS200: RE: sds200 signal bars come and go every couple seconds
ddivine01
I was searching for the reason this was happening on my scanner a few days ago, and stumbled onto this thread from 2019 and in that thread it was determined that this was "Normal" behavior for the SDS200.
I ended up doing a reset of user setting, which then screwed up a local repeater I had added as a quick save when I first got the SDS200, I often listen to the local nets on that repeater, and it didn't do this "Housekeeping" stuff and drop large amounts of the traffic while I was on channel hold.
Well just now I managed to get the freq saved again as a quick save, and it is INDEED holding on channel hold and NOT missing traffic during the net.
I do not know what setting I had screwed up to make it start doing "Housekeeping" and blinking the signal strength bars and missing traffic, but it does NOT normally miss traffic just as a matter of course while on channel hold.
Rant over!!!
Ubbe
Stockholm, Sweden
If you have priority, even DND, set to any function it will override the hold and will go and scan those prio channels at something like each 2 sec.
/Ubbe
ddivine01
Ubbe,
That's what it seemed like, but I've never intentionally set any priority channels, and when it happened, I specifically looked and made sure the priority was turned off.
What do you mean by DND, I don't think I had that on either unless by accident.
I'm actually a VERY simplistic user, took it outta the box, set location zip code and let it go to work, with the addition of the one local 2 meter repeater as a manual entry quick save.
But I do occasionally get lost in the complexity of its capabilities, and undoubtedly did something by accident, that what is so frustrating about it, not knowing what to undo
