Viper43
- Joined
- Jul 23, 2005
- Messages
- 3,272
RE: Submissions not going into the DB
The following was split from the MECA thread for further "discussion":
ummm, not true, I submitted stuff as far back as two years ago and it STILL hasn't been changed and you haven't given any "excuse" for why it hasn't been changed. In fact in Dec or Nov I sent you updates on Hancock Co and, well, no changes made.......and no response as to why the changes weren't made.
Anyway back to MECA I will have some updated TGID's this coming week.
10006 is part of the system wide tac tg 10001 through 10011 are very active I have tried several times to have this put in the DB with no success so again I would urge every one to put these in to that group you can find out a lot of info on these 10001 through 10011 on both Systems 1 and 2
I just reviewed all of your submission to the site and not one of them indicate such. Not sure how you tried, but it certainly wasn't via submission.
Just to be clear, I will change the 10012-10026 to 10001-10011, correct?
OK, I made the changes. In the future, instead of saying you have tried several times to get these into the DB and that we aren't putting them in, please submit the info using the official submit data method (you have used before).
I try to keep tabs on the IN threads, but as a global moderator I read a whole bunch of threads from the entire board and sometimes I miss some local posts. I will never, ever, intentionally ignore information. If there is a reason it doesn't go into the DB I will contact you and let you know the reason.
Thanks![]()
