Yaesu: Re: tiring to get Chrip working on my new HT
hazrat8990
Wyoming
Do you have the correct USB interface for it? I don't know anything about that particular radio, but if it's anything similar to how an 857D is programmed, you will have to get it into cloning mode first. Once the radio is able to talk to the interface, plug in the USB. As soon as your computer sees the interface, the port should show up on Chirp.
k6cpo
San Diego, CA
Yaesu advised against using Chirp software. You can download from the Yaesu website free programming software for the FT-65.
There is also RT Systems. Their software makes both Chirp and the Yaesu software look primitive. There's a cost involved, but it's worth the added convenience of software that works the first time and every time after that.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you have issues with Chirp, it's more likely to find answers here....
Mike
Engine104
Member since 2005
Winnetka, CA
I tried Chirp with my FT-60 for the first time last night and it worked fine. I ordered an aftermarket Yaesu USB cable on Amazon. Make sure you have one that lists your specific HT.
In answer to your question.. (I'm going to assume this is a PC laptop running Windows 11)
Plug in the USB cable first...
To find COM ports on Windows 11, you can use the Device Manager:
Right-click the Start button and select Device Manager
Look for the Ports COM & LPT section
Your RS232 or RS232-USB device should appear with its port number labeled “(COM#)”
If you don't see a Ports COM & LPT section, you don't have any COM ports installed.
Then go back to Chirp to where you were in your screen shot and select the same com port number that showed up in Device Manager.
This worked for me. It is possible that your plug and play is not installing the driver when you insert the USB cable into a port. You should hear a ding.
Hope that helps.
k6cpo
San Diego, CA
Hope that helps.
Yaesu has repeated time after time that they WILL NOT repair radios bricked by using Chirp. You're safer using RT Systems.
