Hello and thank you for the replies. I have two SDS200's. I've set up one of them to have a custom display. I use Sentinel to communicate with the scanners. I wasn't sure if when I read (and saved) from the scanner that I have the way I like, it also backed up the settings for display, weather SAME, etc. so that I could just send that to the second scanner rather than having to manually recreate the settings on the second scanner.
Yes, when you read from the scanner it backs up the settings for display, weather SAME, etc. If you are wanting to take the settings from one SDS 200 and send them to the other SDS 200 so both are mirrored exactly, then yes, read from the first SDS 200 then write to the other SDS 200 and the display and settings will mirror both radios.
If, however, you want differences between the two SDS 200 - say one to have a green System text and the other to have a red System text - then you would need to create two different profiles as
@tvengr mentioned above; otherwise both SDS 200s would have either green or red text for the System field.
