Anyone?
The radio has to be FPP anyways... so change it back to digital?
Sent from my Droid Bionic via Tapatalk 2
Anyone?
I got a similar sound on my HT1250 and PRO3150. DTMF tone with 000 and all the times and pretimes are set to the minimal setting. Its not an exact match but its close enough...
Yes. Disabling the tones using the Tones On/Off selection also disables the talk permit tones when on a trunked system. It makes the radio completely silent except for whatever signals it receives coming out the speaker.If you are on a trunked network, and your radio is programmed to emit tones, if you have the Tones ON/OFF selection enabled in a Mot radio menu, does setting it to "OFF" disable the TPT as well?
No it doesn't. Talk permit or busy tones will always be audible wether the tones setting is set to on or off.Yes. Disabling the tones using the Tones On/Off selection also disables the talk permit tones when on a trunked system. It makes the radio completely silent except for whatever signals it receives coming out the speaker.
...You can customize your own special alert tones (both the duration of each tone and the frequency) and set them to sound when you key up the radio...
I had to learn this the hard way.
I knew you could make different tones for alerts and such, but how in the hell do you set them for TPT/PTT? I thought that was totally separate?
I do that with my cp200s but I do 9999 at 25ms which sounds grrreat!
I would like to ask some info regarding the error encountered on my subject, while downloading the codeplug on 100% suddenly prompted the error, i tried to power off and on all device still same problem. Im using dell laptop, 300 mhz CPU and DOS mode on ASTRO Programming software version 3.0.0.
**Your comment and suggestion is highly appriciated**
Thank you
Not at all. I appreciated the opportunity to learn something new myself. I hope you don't mind my adding your info to the OP.
Can TPT be done on an APX7000?
If you're legally on a trunked system a TPT can be part of your program. Otherwise, the only Motorola radio that will do a TPT today is a TRBO. The TPT on the TRBO means absolutely nothing but it IS a TPT tone.
Yes, I thought of that, but all that hacked tone stuff is just that, and it doesn't sound like a TPT at all. Well, maybe in some vague way it does but we all know what it really is, and it ain't a TPT.
Well I have programmed it on a few XTS5000's in conventional mode and it sounds exactly like TPT. So I am not sure what you mean when you say it doesn't sound like TPT at all. And also, I am not looking to get on to an trunked network. I was inquiring how to do it on conventional channels on an APX7000.
