Realistic 21-1175 Noise cancelling pre amp microphone wiring?
Retroradio
Ontario
Does this mic use the standard Realistic wiring diagram? Most Realistic mics have a shield, red, black, white, Blue Wires
This mic has all those but a yellow wire instead of blue.
I tried the standard wiring ignoring pin2 and no go.....dead mic or bad wiring?......lol
Searched the net and can not find the diagram or instruction booklet that came with it.
Cheers!
CT
See if this helps:
Help with Radioshack 21-1177 power mic
Retroradio
Ontario
Awesome, lots of great info. Maybe if I backwards engineer the conversion from Cobra back if that makes sense. Ive bookmarked this so I can refer to it later. :)
The big issue is that this seems too be a non standard wiring pattern due to the noise cancelling. It does not have a BLUE wire it has a YELLOW wire along with the black, white , red and shield. The OP posted their wire colour scheme and it was blue...Very confusing.
I tried the traditional wiring Asumming the yellow and blue were the same and no receive it transmit.
Anyone ever see a RS mic with these wire colour codes?
