I swear this radio was messed up before I touched it.
I found another DX-302 for a song on eBay. It was described as deaf but when I got it, I could absolutely receive some strong stations. And the MHz gear was perfect. I was pretty happy about that.
Initially, receive was weak and the audio was very scratchy. Deoxit helped things some. Then I replaced 12 caps, replaced the speaker and swapped out the entire attenuator board from donor parts (the selectivity switch was broken.) It still isn't right and I'm not sure where next to turn for troubleshooting.
Now that i've replaced the caps in the audio section, I get quite a bit of low end when "AM" is chosen but lose all the bass when switched to "AM ANL." Not sure if that's normal. My "good" one does that too and the caps in its audio section were replaced as well. Is that a "symptom" of performing W4JBM's audio mod?
My big issue is the "pumping" of strong signals and the lack of movement from the signal meter when strong signals are present. In fact, the needle moves very little at all. Reception seems to fade in and out far more than it should. An A/B comparison with the "good" DX-302 proves that. At times the radio is overloading and at others, I have to turn up the volume. Lastly, single sideband is only intelligible when the BFO knob is set to one extreme.
I love a challenge and I have some handy tools, but my skill set is not that strong. I'm above the beginner level but lacking in many electronics troubleshooting skills. Most of what I know has come from watching Youtube videos and learning from my own mistakes. With these symptoms, should I be focusing my attention in one area more than another? I haven't touched the RF board, except to clip R227, which mutes the MHz dial when tuning. I did that on both radios.
I appreciate any advice you can give.
Thanks,
Dominic
Thanks,
Dominic
