Realistic PRO-16A Questions
kramden66
Does this use the 10.7 crystals?
Are crystals available anywhere
Does this have actual light bulbs not led lights ?
pro92b
Mutated Member
PRO-16A owner's and service manuals are both available at RadioPics Database - RadioShack/Realistic - Patrolman PRO-16A
The service manual details crystal specifications on page 3 as follows
VHF LOW crystal frequency (MHz) = Fr + 10.7
VHF HIGH crystal frequency (MHz) = (Fr - 10.7) / 3
UHF crystal frequency (MHz) = (Fr - 44) / 9
Fr is the desired receive frequency in MHz
The UHF crystals are unusual and the more common 10.7 MHz UHF crystals do not work in the PRO-16A.
The service manual lists the incandescent lamps on pages 25 and 30; rating is 14V at 50mA.
gmclam
Fair Oaks, CA
This is true. The UHF receiver is Triple Conversion whereas most other radios at that time were only double conversion. So, for example, a UHF crystal from a PRO-5 (which is still 10.7MHz IF) won't work on the PRO-16.
kramden66
Wow thanks gmclam , pro92b and bb91
So are the UHF crystal the direct frequency ? example 462.450 would be 462.450 ?
gmclam
Fair Oaks, CA
No. Pro92b gave you the answer: UHF crystal frequency (MHz) = (Fr - 44) / 9
Use a crystal with frequency of 46.49 MHz:
(46.490 MHz * 9) + 54.7 MHz - 10.7 MHz = 452.450 MHz
