Realistic TRC-449 - Powers On, But Not Transmitting?
itsanss
Hey, ya'll. Happy Thanksgiving!
I am brand new to CBs, but am having a blast figuring it out!
I inherited a couple of radios and an SWR meter from a recently-passed family member - a Realistic TRC-449 (chrome face), a President AX7, and a GC Electronics SWR analog meter.
I excitedly hooked up an AC to DC converter to each radio. Success! Both power up and I can cycle through the channels! I also hooked up an external speaker and was able to make that work. All the features seem to be functional.
I felt confident enough to forge ahead with buying an antenna, a cable, and some other accoutrements to be able to use the CB(s) in my pickup truck. I painstakingly installed the antenna, ran the coaxial, installed a PA speaker outside the cab, ran wires, fuses, plugs, etc.
Finally the time came to turn on the CB and see what happens when actually hooked to an antenna. The TRC-449 powered right up as expected. I cycled through the channels, 1-40, in AM, LSB, and USB. I heard no chatter. I also played with the NB/OUT selector - nothing.
I plugged in my SWR meter and there was no life to the meter whatsoever. My first thought was that the meter was defective. Would not surprise me since it's probably 30+ years old and I have no idea of its life history. Then it occured to me to try the President radio, just as a test of my setup and of my meter.
I hooked the President up and there were multiple channels that I was hearing chatter on. It was so freaking cool! I then hooked in my meter and followed some instructions I found in a YouTube video. I did not do a true tuning of the antenna, but just wanted to see if I got similar results as the person in the video to see if I was even barking up the right tree. The meter seemed to do what it was supposed to.
So.....it would appear that my TRC-449 is not transmitting. This is the radio of the two that I have that I would prefer to use!
From some other YouTube videos I've seen, older radios tend to have capacitor problems. Is that where I should start? Is that something a novice should be attempting? What would it cost to have someone go through the radio and bring it up to snuff?
Thanks in advance from SW Oklahoma!
slowmover
Fort Worth
Welcome!
Well told start. That’s appreciated.
We’ve all been in those shoes.
AM/SSB
Built 1977-8X
There are men enjoy repairing radios.
I’m not one of them.
Given desire for AM/SSB — and modern performance (integrated NRC and truly stable SSB) it’s hard to beat a number of choices from about $175 to $475.
A current sale on one (my choice) is the RadiOddity QT60 at $199.99
This is what I use in the big truck. (Used to run US-183 from US-287 to Seiling, OK pretty often)
I’m not trying to advise you on a path so much as pointing out that even were the 449 brand-new it’s not in the league of today’s radios, overall.
Adjusted 1985 $370 449 price today is $1,100.
The $199 QT60 is superior in performance.
Hear, and Get Heard
Is the goal
You should go the path which most appeals.
A TRC-449 is highly-regarded.
Will always be a buyer for a nice one.
The link (below) is a detailed look at mobile installation of amateur radio. Most of which applies to us. You’ll want to go over how well the antenna chosen and mount location is near best. Same for quiet 13.3V power. Etc.
You could start a thread on that aspect of things. (Pickup install). Keep radio or install questions to separate threads is how I’d do it.
In the end the radio chosen is just a component we plug-in. The systems which run it are the real focus. Make any radio shine.
Mobile Radio Installation Bible
tramd
I just came across this post. You say it doesn't transmit, but also stated that you couldn't hear anything. That radio was made in 1977 and 1978. They are very good radios. In a radio that is almost 50 years old, it's going to need some work if it has never been reworked before. Most likely, the electrolytic capacitors will need replacing to make it work as it should. They will usually all look good, but are worn out and past their lifetime. That radio also has a relay that can become problematic. Sometimes just pulling it out of its socket and putting in back in a few times will clean up the contacts enough to make it work. Other times it needs to be replaced as it is defective. This radio has the same circuit board as its big brothers, the TRC457 and TRC458, along with a few other popular radios from other manufacturers. Capacitor kits can be bought for about $40.00 including shipping. If you don't know how to solder, then I would advise getting someone who does and understands electronics to work on it for you. It may have other issues besides old caps. I have resurrected many old radios that just needed new caps and an alignment.
