Rearranging favorite lists in Proscan
JoplinFossil
Joplin, Mo
New to Proscan(just purchased). I’m using a combination of Sentinel and Proscan until I become a little more familiar with Proscan. My problem is I created my favorite list and rearranged it in Sentinel, saved it to my BCD436HP. All was well till I went to Proscan and read from the scanner. It’s not in the order it’s in Sentinel or on the scanner. I can’t find a way to rearrange it in Proscan or get Proscan to read it like it’s in Sentinel and on the Scanner. Ideas???
ProScan
Software Provider
Ontario, Calif.
How are you determining the FL order in the scanner? If you haven't already, go to the menu - Manage Favorites and note the order. ProScan will read in that order.
{edit} To arrange the FL in ProScan, click on a FL node then drag it to the desired location.
JoplinFossil
Joplin, Mo
That’s my problem. My favorite lists in the scanner they are in order but when I read from the scanner to Procom they do not change.
ProScan
Software Provider
Ontario, Calif.
If you already have the favorites in ProScan with the same names, then those favorites will overwrite and stay in the same order.
Delete the FL in ProScan then try to read.
Just so we are on the same page. Is this the screen in the scanner that you are using to determine the order of the FL?
