Rebanded systems
scanfan03
Houston, Texas
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 4.0.4; en-us; DROID BIONIC 4G Build/6.7.2-223_DBN_M4-23) AppleWebKit/534.30 (KHTML, like Gecko) Version/4.0 Mobile Safari/534.30)
Is there any way to use a Type I radio to monitor a rebanded system? Doesn't type I have fleet maps so therefore you would be able to change the channel lineup?
RBMTS
No sir. Rebanding involved changing the frequencies designated to actual channel numbers in the Motorola logic. You and I know them as frequencies, but to a Motorola radio, they only know channel numbers. So prior to rebanding, 860.9875 might have been channel 128 (I'm just guessing here to use it as an example). Post-rebanding might mean that channel 128 is now a totally different frequency. So when the radio is listening to the control channel and receives a command that a talk group call request is being put on channel XXX, that will be a totally different frequency than what your old radio knows it to be. Hopefully I'm getting the point across.
The other fact is that I don't think there is any Type I systems still in use for public safety (but I could be wrong). I believe everyone as moved to at least a Type II or P25 type trunk system. A Type I radio will not work due to the mix of standard and splinter frequencies that the system will use.
The old Privacy Plus Type I radios are now only good for conventional, if they had that capability.
KE4ZNR
Radio Geek
I sure as heck hope not :D
If there is one out there somewhere someone needs to hire a new
system admin and/or radio shop :cool:
Marshall KE4ZNR
scanfan03
Houston, Texas
I understand the concept of rebanding. I thought that you set the lcn plan up through the software on type I systems like UHF and VHF trunking. I guess i thought wrong haha. But i do know you can listen to a type II system on a type I radio (at least with the standard GX5800T).
RBMTS
ONLY if the system has only splinter or only standard frequencies. A type I radio will not work on a type II system that uses a combination of both sets of frequencies.
