AlanTilles said:
Of course I know about channel assignments. That's the whole reason that Motorola had to re-write software (and M/A-Com didn't). In Motorola's system, frequencies were assigned by channel number, not frequency. Therefore, 851.0125 was Channel 1, 851.0375 was Channel 2. In the NPSPAC band, such channel numbers already corresponded to the fact that the NPSPAC frequencies are spaced every 12.5 kHz (even though the equipment is not narrowband, requiring geographic separation). Going forward, in the Motorola scheme, Channel 1 is still 851.0125, but Channel 2 will be 851.0250
Not quite. Note that we, as scanner users, are always referring to
Motorola's channel numbers, as they appear in the 3600 bps control channel messages. Any other channel numbering scheme (e.g. "channel 2 will be 851.0250") is irrelevant for our purposes, and discussing it only confuses things.
Motorola 3600 CCs send a 10-bit channel number that ranges from 0 to 1023, with some "holes" of unused channels.
Pre-rebanding, channels 0-719 are assigned to 851.0125 - 868.9875 on 25 kHz steps. To handle "rebanding", channels 440-559 are moved from 862.0125 down to 851.0250, still on 25 kHz steps, but now interleaved with channels 0-119 - for a resulting 12.5 kHz spacing.
The result is:
Channel 000: 851.0125
Channel 440: 851.0250
Channel 001: 851.0375
Channel 441: 851.0500
Or:
Channels 000-439: 851.0125 - 861.9875 on 25.000 kHz steps
Channels 440-559: 851.0250 - 854.0000 on 25.000 kHz steps
Channels 560-719: 865.0125 - 868.9875 on 25.000 kHz steps
Chanenls 720-759: 866.0000 - 866.9750 on 25.000 kHz steps
(Whether any given channel number is actually used on a rebanded system is also irrelevant for our purposes; all we're concerned with is the "shifting" of channels 440-559).
This behavior has been confirmed by people monitoring "rebanded" Mot 3600 systems. Using scanners that support it, people have "remapped" channels 440-559 in their scanners, changed the control channel frequencies if required, and the rebanded systems are monitorable again.
