Rebanding has begun on Motorola trunked systems
scannerfreak
Well Known Member
Indiana
DaveIN said:
At least two systems have been discovered to be using newly rebanded frequencies and no longer are being trunk scanned correctly using the current trunking scanners.
Albertville, Alabama: http://www.radioreference.com/apps/db/?sid=1462
Vacaville, CA: http://www.radioreference.com/apps/db/?sid=778
Please report in if you are seeing this on your local Motorola analog or mixed mode system.
If you can log the system using UniTrunker or Trunker it would also be helpful to the cause.
Here are some resources:
http://wiki.radioreference.com/index.php/Rebanding
http://www.800ta.org/content/800Mhz/call_sign.asp
http://wiki.radioreference.com/index.php/Trunked_Radio_Decoders
Discussion here:
http://www.radioreference.com/forums/showthread.php?t=100058
WayneH
Forums Veteran
Super Moderator
Your master site
I've released information on how to program specific GRE or RadioShack digital scanners for rebanded systems in the following threads. There is currently no solution for Uniden scanners so please be patient until they release a firmware patch (if your model supports them).
RadioShack's PRO-96 and 2096
GRE models
