Rebanding in MD Eastern Shore Consortium
mouse1
silver spring maryland
I know rebanding took place last fall in the Consortium. I rebanded my digital trunking scanner -15 on this trunk. It shows the signal and the identifiers however I am receiving no audio. Example it shows Easton PD yet I hear nothing. Any suggestions ? Thanks
troymail
Silent Key
What kind / model of radio are you using? How do you program it - manually? Software with RR download?
Some radios require specific versions of firmware and there are usually some addition setting changes required other than just entering the -15 Mhz frequencies.
boatbod
Talbot Co, MD
Rebanding just the control channel frequencies will not get you audio. You need to change the channel mapping too.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you are using a radio that's supported by the RR Web service (and the appropriate app), when you download the system you should get all the rebanding related changes, too. You need to have a premium subscription to make that work...which is described here...
Premium Subscription Information Page
Mike
