northzone said:Actually, it will affect ALL 800mhz trunked systems even if they are not within those frequencies ranges. That is because the channels will be renumbered for the whole band. This affects the way the control channel assigns frequencies on all systems, new radios (with the new numbering plan) vs. old, etc.
Agreed. Grab something to drink, get comfortable and go to the Rebanding Sticky atn4voxgill said:You can find information on the other rebanding string, no need to start another one here.
Systems that are entirely within the portion of the band not being moved will not necessarily need to be touched.
northzone said:Systems that are entirely within the portion of the band not being moved will not necessarily need to be touched.
Then what happens when all the channels are renumbered (fcc channel numbers) and they want to add a new portable or mobile to their system? It will not work because the channel numbering is wrong. Somewhere along the line everybody is going to need to upgrade their firmware to the new numbering plan regardless if they are in the affected ranges or not. It really creates quite a nightmare of old vs. new equipment.
northzone said:Then what happens when all the channels are renumbered (fcc channel numbers) and they want to add a new portable or mobile to their system? It will not work because the channel numbering is wrong. Somewhere along the line everybody is going to need to upgrade their firmware to the new numbering plan regardless if they are in the affected ranges or not. It really creates quite a nightmare of old vs. new equipment.
