I want to receive Starcom 21 transmissions used by the Illinois State Police. I found out it requires a phase 2 scanner. I need help with entering the info on a Uniden scanner. Is it possible to listen to these transmissions? I am considering Uniden BCD996P2 Digital Mobile TrunkTracker V Scanner. I would be so happy if I could. Thanks!
STARCOM21 is listed as a P25 Phase II system because that's how it is identified on control channel data. However, at this time, the database shows that the majority of talkgroups are P25 Phase I, as shown by a
D in the Mode column. Talkgroups using Phase II are shown as a
T in the mode column. Taking a quick look at the database, some counties have apparently gone to Phase II, some are all Phase I, and some have both Phase I & Phase II talkgroups in use.
However, that does not matter. The 996P2 can receive both Phase I and Phase II talkgroups. Programming the scanner is the same regardless of which mode is used. You use the same system type for either. Some counties are mostly in the clear, others mostly encrypted, some are mixed. Find your county in the database page for the system to see which, if any, of the agencies you want to monitor are encrypted. Encryption is noted by the letter
E appended to the Mode designator. A
Capital E such as
DE or
TE, means that the talkgroup is always encrypted. If a
Lower Case e is shown, such as
De or
Te, then transmissions are encrypted only part of the time.
The other thing to check on, which probably would be done best in the Illinois Forum, is whether there are
Simulcast issues in your area. I would suggest that you request to have your thread moved to the state forum, where someone in the area would be more likely to see it, & advise if there are reception issues or not. To do that, do
not create a new thread. Instead, click on the Report in the lower left corner of one of your posts, and request that a moderator move your thread to the state forum.
