Receiving Issue
Para078
Tx.
Does anyone know if Uniden plans on a fix for the occasional not receiving issue?
mc48
Monroe County, NY
Mine would just sit there sometimes when I turned it on, I would turn it off then back on and it would start receiving.
This was a couple years ago, then it just went away, there was not an update and I didn't change anything.
n1chu
Farmington, Connecticut
I believe you are referring to what some are reporting as a loss of audio. The scanner continues to scan, stopping on busy channels/TG’s but there is no audio. Turning the scanner off and then back on brought it back to life.
To date, I haven’t heard anything about a fix, a recall or firmware update.
werinshades
Chicago , IL
How did you get that....?
.....out of this? Is this going to turn into another bit** session about a scanner, or is their a specific issue that is resolvable and requires a programming adjustment?
n1chu
The OP’s question was vague. So I took a shot at the “no audio” issue (which has affected my two SDS200’s). What is a bit** session?
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
How occasional? What isn't received: TRS's? Conventional Objects? NOAA weather radio? All of the above? No info given will only garner more questions from the respondents
werinshades
Chicago , IL
Yes, that's why I asked to elaborate. I could "assume" many different things that could be the issue and post a laundry list but refrained from doing so to not start another bit** (rhymes with witch:unsure:) session.
