Receiving strength of mobile vs. handheld
resqpig
Blacksburg, VA
I was just wondering if anyone had an opinion on the receiving strength of the PSR-500 over the PSR-600. As the area I live in will be going digital in some areas soon, I will have to make a decision of mobile vs. handheld. My experience with the recent Uniden scanners has found a significant increase with reception by the mobiles. My handheld performs poorly with the stock antenna and/or an external antenna. I would like to get a the PSR-500 due to portability, but I don't want to sacrifice reception. I would be using an external antenna in my vehicles with the PSR-500.
RKG
Boston, MA
The "receiving strength" of a receiver is properly called its "sensitivity." I believe the PSR-500 and -600 have the same sensitivity, since they have basically the same electronics.
Of far greater impact on what you can actually hear is your antenna/feedline installation, as this provides the signal to your receiver. In general, an external antenna, particularly one that is tuned to a particular band, feed with low loss coax, will provide a greater signal strength to the antenna terminals of a receiver than a simple portable or "back of the box" antenna.
Jakemcgraw
Dalmatia, PA.
In alot of my experiences, I had to give a slight edge to the base/mobile over the handheld of the same, meaning when I owned my pro-97 and pro-2055, which are basically the same internals,,Ive always noted less intermod and clearer transmissions with the base and even if using the same antennas on both. I have noticed this on several base and handheld combinations i had over the years . Ive heard some say already maybe the steel chasis of the base helps with intermod and such,, of coarse areas and conditions differ widely.
fireant
Copland
Seen it both however was programming a friends Pro 2055 this week and had my Pro 97 on my 97 seemed to be more sensitive but I think it depends unit to unit. I have 2 Pro 95's as well my first one is not quite as sensitive as my second one. I think its a case to case however the PSR 500/600 is a great scanner.
Maybe someone who has both units can test the sensitivity for us to help you out. Any share with us the results.
fireant
zz0468
Banned
A portable radio operated on a persons hip, ie mounted with a belt clip, is going to have about a 13-20 db disadvantage over a mobile receiver using a roof mounted antenna. That's assuming portable and mobile performance are otherwise about the same.
GTO_04
Noblesville, IN
I own both the 396 and the PSR-500, and the PSR-500 is significantly more sensitive on 800 MHz. It is at least as good or better than my Uniden 796 base station.
GTO_04
resqpig
Blacksburg, VA
I appreciate the pointers that everyone has given thus far. I guess I didn't make it clear before, I used to run my 396 on an external antenna and there was an extremely noticeable difference compared to the PRO-2055 I have on the same external antenna now. This was most notable on 800, but still noticeable on all bands. Both were being run on a MON 752. The 2051 now has impressive sensitivity and I anticipate the PSR 500 or 600 will be even better.
Fireant, I agree it would be nice to hear from someone that has both the 500 and 600.
