As you may have noticed HF propagation is a bit lower. Not because of solar flux. Solar flux is still in the good range at 159sfu.
AR3229 fired off a S1 radiation level storm and a halo CME. On top of that a coronal hole has rotated in Earth strike zone with 764km/s (has waned to 680km/s) solar wind stream. The effects should wear off in a window of less than 5 Earth days. That is depending on AR3229 behavior as well as the other active regions. Aurora chasers will benefit from this solar storm event.
Some graphs for representation from LMSAL SolarSoft. Indicates activity.
Maximum Aurora forecast 104.3GW >90% probability.
