reception
steve9465
ocean city Maryland
Is it normal or do you think I can fix this. I receive a transmission but most of the time mid way through it , it stops and then continues with the rest of the message. This causes me to miss some stuff and it seems as though it is on purpose from the system.??
ab5r
Steve, you did not identify what receiver you were using. If it was a scanner, check to see if possibly the settings allow for occasionally checking a preset frequency or NOAA weather? That could cause intermittent breaks as it goes over to check the other frequency and then returns.
lmrtek
could be a strong nearby signal like a telemetry system keying up and desensing your receive
