RFI-EMI-GUY
- Joined
- Dec 22, 2013
- Messages
- 7,386
So I have some primary disposable Li/MnO2 batteries that were manufactured well over 20 years ago for a Motorola Saber radio. Two of them, unused, seem to have a high level of charge remaining. Estimated 75 or 80 percent based on published self discharge rate and having over 3.1 volts per cell. These are sealed 9 volt packs consisting of 3 cells. One of the batteries was used but has about 2,8V per cell.
The literature says you cannot safely recharge these. However there are coin cells that are rechargeable at about a C/15 rate (15%).
The precautions are that the usual dealing with heat and sparking, but also with dendrites from the lithium reforming as a crystal.
I am considering to apply a constant voltage to the ~1800 mAh pack at a greatly reduced charge rate of 2% this would equate to about 36 mA * which is very little energy.
Could this be done safely and effectively? Has anyone done this successfully?
* Edit; They are 4200 mAh so 2% would be 84 mA which is still pretty low. I can go lower.
