For some reason the windows media end of the Edmonton feed as listed above is showing as failing the daily test, however the winamp feed seems to pass with no problems. E-Man, would you mind checking both feeds with your Sangean and see if they play? The first URL is showing as passing the daily stream test and the second is showing as failed.
